Is there a way to view decimal time in the timesheet view?
I have set Toggl to use decimal time as we use Project Server for timesheets and that uses decimal time. However, the timesheet view still displays the daily project totals as hh:mm but the totals at the end and the bottom of the rows are in decimal time.
Is there any way to set decimal time for the project totals for each day?
And yes, I have set my profile preference to decimal time:
Heya Dave! This is a great observation; our team has received this information and they will be looking into any potential adjustments/changes that need to be made.
Having this issue as well. I have my duration display format set to decimal but the totals are still rounding to 0.1. It would be great if the totals were in .25h increments, because 15 min blocks are pretty standard.
To clarify, I was hoping to get values like 1.75 and 6.75, although I would also be fine with the totals being 1:45 and 6:45, either is better than 1.8/6.8.
I have the same issue. Any updates @Support ?
No updates to share at this time, but thank you for checking!
Note: The “workload” view in reports is basically the same but has decimal time. If you use the timesheet view to transfer your data to another tool (like me) you could use it.
