“Me” Endpoints - GET ProjectsPaginated
https://api.track.toggl.com/api/v9/me/projects/paginated
Get paginated projects.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::GET, "https://api.track.toggl.com/api/v9/me/projects/paginated".to_string())  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
Query​
start_project_id integer false Project ID to resume the next pagination from.
since integer false Retrieve projects created/modified/deleted since this date using UNIX timestamp.
per_page integer false Number of items per page, default 201.
items Array of object -
items​
active boolean Whether the project is active or archived
actual_hours integer null
actual_seconds integer null
at string Last updated date
auto_estimates boolean null
billable boolean null
can_track_time boolean -
cid integer Client ID legacy field
client_id integer null
color string Color
created_at string Creation date
currency string null
current_period object Current project period, premium feature
end_date string End date
estimated_hours integer null
fixed_fee number Fixed fee, premium feature
id integer Project ID
is_private boolean Whether the project is private
is_shared boolean Shared Project
name string Name
permissions string -
pinned boolean -
rate number Hourly rate
rate_last_updated string null
recurring boolean Whether the project is recurring, premium feature
recurring_parameters Array of object Project recurring parameters, premium feature
shared_at string -
shared_hash string -
start_date string Start date
status string Status of the project (upcoming, active, ended, archived, deleted)
tasks_count integer -
template boolean null
template_id integer null
wid integer Workspace ID legacy field
current_period​
end_date string -
start_date string -
recurring_parameters​
custom_period integer Custom period, used when “period” field is “custom”
estimated_seconds integer Estimated seconds
parameter_end_date string null
parameter_start_date string Recurring start date
period string Period
project_start_date string Project start date
Operation Forbidden
