“Projects” Endpoints GET Workspace Projects
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/projects
Get projects for given workspace.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::GET, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/projects".to_string())  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
Parameters
Path
Query
sort_pinned boolean true Place pinned projects at top of response
Query
active boolean false Return active or inactive project. You can pass ‘both’ to get both active and inactive projects.
since integer false Retrieve projects created/modified/deleted since this date using UNIX timestamp.
billable boolean false billable
user_ids array false user_ids
client_ids array false client_ids
group_ids array false group_ids
statuses array false statuses
name string true name
page integer true page
sort_field string true sort_field
sort_order string true sort_order
only_templates boolean true only_templates
only_me boolean false get only projects assigned to the current user
per_page integer false Number of items per page, default 151. Cannot exceed 200.
Response
200
items Array of object -
items
active boolean Whether the project is active or archived
actual_hours integer null
actual_seconds integer null
at string Last updated date
auto_estimates boolean null
billable boolean null
can_track_time boolean -
cid integer Client ID legacy field
client_id integer null
color string Color
created_at string Creation date
currency string null
current_period object Current project period, premium feature
end_date string End date
estimated_hours integer null
fixed_fee number Fixed fee, premium feature
id integer Project ID
is_private boolean Whether the project is private
is_shared boolean Shared Project
name string Name
permissions string -
pinned boolean -
rate number Hourly rate
rate_last_updated string null
recurring boolean Whether the project is recurring, premium feature
recurring_parameters Array of object Project recurring parameters, premium feature
shared_at string -
shared_hash string -
start_date string Start date
status string Status of the project (upcoming, active, ended, archived, deleted)
tasks_count integer -
template boolean null
template_id integer null
wid integer Workspace ID legacy field
current_period
end_date string -
start_date string -
custom_period integer Custom period, used when “period” field is “custom”
estimated_seconds integer Estimated seconds
parameter_end_date string null
parameter_start_date string Recurring start date
period string Period
project_start_date string Project start date
403
500
On your API page
you have an external_reference field. If I use the GET projects request i dont get this field.
Also on the post Reference I cant find if it is allowed to use zje integration_XYZ fields.
I would like to pass a reference to my manually synced JIRA projects.
Also I would like to pass a reference to the TASKS Api. is there an external reference field?
@FiBu Hi :waving_hand:
For the external_reference field to be returned, it needs to be set first. Sending external_reference in the payload should put that reference in the project. Can you confirm you did that and still can’t get the external_reference back with a GET call?
Those 3 fields (integration_ext_id, integration_ext_type, and integration_provider) are managed by the Asana/JIRA/SalesForce integrations internally, they cannot be manipulated through the public API and will only be delivered through the API when they actually have data.
If those fields are absent from the API, it’s because there is no link between that Track Entity and the Asana/JIRA/SF entity.
Currently, the external_reference field can only be used with Projects and Clients. I’ll share the ability to use it with Tasks as a feature request on your behalf with our product team.
Hi,
I’ve got an issue with this endpoint. I have a project with tasks. The project is set to recurring monthly and estimates are task-based. My tasks have estimates.
The recurring parameter estimated_seconds always returns 0. Any idea why ?
I was expected the monthly estimate in this field.
