Feature/Bug: Can the Tasks view in Projects work on narrow widths? Currently when this view gets narrow the task name column becomes unreadable and the whole view is unusable.
The reason I want to be able to have the narrow width working is so that I can have two windows open and split screen - the left being my current project tasks and the right being my current timer.
That’s a great use case - having your project tasks and timer visible side by side is a very practical workflow. Unfortunately, a responsive narrow-width layout for the Tasks view in Projects is not currently available in Toggl Track, and the behavior you’re describing does sound like a usability issue at smaller widths.
As a workaround, you might consider using the timer’s project and task selector directly to navigate your tasks without needing the Projects view open alongside it. When starting a time entry, you can select the project and then pick a task from within the timer itself, which could reduce the need to have both windows open simultaneously.
I’ll make sure to pass your feedback about the narrow-width Tasks view along to the product team - it’s a reasonable improvement to ask for, especially for users who like to work with split-screen setups.
