Increase width of Project column or make columns resizable
The Project column is extremely narrow on the Projects screen, to the point that it can be very difficult to tell projects apart or even tell what they are at all.
If the window is narrow enough (in this case about half my 14" screen’s width) under 10 characters fit.
Ideally this would expand out to occupy the large amount of space available to the right. I don’t use Billable Status but I can’t imagine it needs as much room as it gets.
Another possible solution would be to make the columns resizable. Right now I often have to click into projects to figure out which one I need, which is a pretty rough user experience.
Hey @stevenbyenzer
I’ll pass this on to the team as a feature request :blush:
Have a lovely day!
