Notification sound when a session or break ENDS
Hello,
I’ve downloaded the Android app, and so far I love it, except for one thing. I can’t find a way to get a notification sound when a session or break ends. Without that I will routinely not realize that it’s time to stop or start working. I don’t want to keep having to pull my phone out of my pocket to see how much time is left. Is there a setting to enable this? Seems like it would be pretty straightforward, and it’s available in most of the other Pomodoro apps I’ve tried (including TickTick, which is what I have been using). I guess as a workaround I could use the automatically start setting, so I would get that sound, but that’s less than ideal for me.
Hi! Thanks for this feedback!
The workaround you mentioned is what I would suggest as well with the current settings that are available. Enabling auto start for breaks and sessions would give you the sound notification you need.
With that said, this is a great candidate for a feature request. Would you mind if I move your post Product Feedback ?
Hi!
Yeah the workaround works, but isn’t perfect because I’m not always ready to actually move on. This is further compounded by something else I just noticed, there’s no pause? Clicking “Stop” prompts me to end/skip the session. So I can’t set it to auto-start the next session and then pause that if I’m not actually ready to move on. Also, what if I need to use the bathroom, or take the dog out, or something? I don’t always want to skip, I just need to pause.
Maybe that would be a separate feature suggestion, but something I would also need to be able to migrate to this tool from TickTick.
Thanks!
That is correct; a running timer can only be stopped and continued afterward; pausing it is currently not an option. However, tracked Time Entries with similar details are grouped together in the list view on the Timer Page as far as visualizing time goes, but I do understand how that can interrupt a Pomodoro flow. There is a constant debate on what Pomodoro should be; based on the original idea, it should be about uninterrupted focus on a task for a period of time, but nowadays, it feels like workflows are hard to manage that way - we will try to bring improvements to our apps to allow deep focus in the future :slight_smile:
All noted and shared with our product team! Thank you! :raised_hands:
Hi! Wondering if there was any update on this? Thanks!
@Taylor_Huston I’m afraid that, due to volume of feature requests our product team has on their plate to review (we do really go through each one) the turnover time is not that short, if the request you made gets implemented we will be sure to let you know :slight_smile:
Just want to bump the pause button, this would be extremely helpful for pomodoro’s if it can be figured out!
Love the product, thanks so much :slight_smile:
Sound at the END of a work session or break is vital.
I love the product, but without a loud signal at the end of pomodoro session and breaks, that feature is dead and useless to me. I’d pause any high level improvements to reporting etc for this basic function to be rock solid and useful.
Keep up the great work. I do respect your need to prioritize, just chipping in my voice/vote.
I think the design choice of focusing on session/break start may have been a mistake on the app developers part. Really, why would I need those notifications? I know when a session starts because I start it. Switch instead to configuring the session/break end. This makes much more sense and better matches the original Pomodoro technique.
Hello… for some reason on my Toggl Browser Extension, whenever my four entire sessions are over which will trigger a long break, it doesn’t ring the sound as soon as the break ends. I would have to check it myself which, if it weren’t the case, could save me some time lost from accidentally overstaying my break. The notification sounds always ring to tell me if the session is over and when the short breaks end, so I was wondering if this is a bug.
Your response is greatly appreciated. I just wanna know… thanks in advance. :disappointed_face:
Hey there! Could you confirm the browser extension version you are on please?
i think notification sound on stop is a critical feature for android. i would feel more inclined to use this product if it had it, without this auto-start timer workaround.
i guess the issue is that timers only play a sound when they begin, not end. which is why when auto-start is disabled, no sound is played once it reaches the end.
however, if auto-start is disabled, i think its natural a user would want to know the timer stopped, especially on android, where we cannot always see the timer on screen.
