Persistent smart suggestion pop up
Toggl
Topic content
Hello -
I’m having trouble with my Mac. Everytime I try and do something, I get an oh-so-helpful pop up asking me if I want to track it.
Smart Suggestions and Auto-Tracker are both off, and I don’t have notifications enabled. I’m running version 1.9.1, and this prompt still appears. I’ve deleted the library files and tried to get it to reset itself. No luck.
Same issue here, +1.
Turning off activity recording isn’t an option for me. The My activity timeline is the main reason I use the desktop app: I can see what I worked on and log the time myself afterwards. But these pop-ups keep interrupting me and are really disruptive and distracting during work.
Old version hasn’t got this notifications.
I came here with the same question. Adding this note in case it helps to get a response. It seems really weird that you can’t turn this off? The only solution is to track something all the time (or quit the app), but neither of these work well for my workflow.
Had a response… apparently you need to
  1. Open the Toggl desktop app and go to My activity.
  2. Click the AI button above the timeline (Name activities with AI). The panel is titled “Name your activity on this device”.
  3. Set Suggest current work to Off.
That setting is for this computer only. If the card still appears after it’s set to Off, reply here and we’ll take another look.
You only need to turn off activity recording if you want My activity itself off: profile menu → Desktop settings → Activity timeline → turn off Enable activity recording. Suggest current work → Off is enough to stop the card.
Oh, that was hard to find, but definitely the answer. Thank you so much!
