UPDATE: Restoring via TimeMachine to 10.15.0 (2986) (which is what it’s called in the “About Toggl Track” dialog) worked, further pointing to the problem being the latest update.
My Toggl Track (v4.50.128 / 10.16.0 according to App Store, macOS 26.4.1) won’t open, even after deleting it from my Application folder and reinstalling it from the App Store. It worked fine on Thursday, but I see that the latest version was released on Friday.
The iOS app and the Toggl website work just fine. A complete reboot didn’t help either…
Is there a key combination one can hold when starting up to make it reset the preferences, or something similar?
I can’t seem to attach the full crash log here, so here’s the first part.
Translated Report
Process: Toggl Track [22873]
Path: /Applications/Toggl Track.app/Contents/MacOS/Toggl Track
Identifier: com.toggl.daneel
Version: 10.16.0 (2987)
Code Type: ARM-64 (Native)
Role: Foreground
Parent Process: launchd [1]
Coalition: com.toggl.daneel [29273]
User ID: 501
Date/Time: 2026-06-01 13:40:44.3462 +0200
Launch Time: 2026-06-01 13:40:43.7304 +0200
Hardware Model: Mac16,8
OS Version: macOS 26.4.1 (25E253)
Release Type: User
Crash Reporter Key: 0A80D1EF-73E6-D4F8-3C90-637F26692C75
Incident Identifier: 9A43C12A-E230-42FB-B06F-EB6FCA2B12C8
Sleep/Wake UUID: 11A69BE1-4D44-4CBE-B1A3-4DEDAC7E286C
Time Awake Since Boot: 12000 seconds
Time Since Wake: 11404 seconds
System Integrity Protection: enabled
Triggered by Thread: 0, Dispatch Queue: com.apple.main-thread
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000001, 0x000000019d2f3cc8
Termination Reason: Namespace SIGNAL, Code 5, Trace/BPT trap: 5
Terminating Process: exc handler [22873]
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libswiftCore.dylib 0x19d2f3cc8 assertionFailure(:_:file:line:flags:) + 172
1 Toggl Track 0x1051b21dc 0x104a68000 + 7643612
2 Toggl Track 0x1051b2230 0x104a68000 + 7643696
3 CoreData 0x1916028a0 -[NSPersistentStoreCoordinator _doAddPersistentStoreWithDescription:privateCopy:completeOnMainThread:withHandler:] + 668
4 CoreData 0x1916025a8 -[NSPersistentStoreCoordinator addPersistentStoreWithDescription:completionHandler:] + 228
5 CoreData 0x191822e54 -[NSPersistentContainer _loadStoreDescriptions:withCompletionHandler:] + 256
6 CoreData 0x1916020b8 -[NSPersistentContainer loadPersistentStoresWithCompletionHandler:] + 264
7 Toggl Track 0x1051b18dc 0x104a68000 + 7641308
8 Toggl Track 0x1051b3a50 0x104a68000 + 7649872
9 Toggl Track 0x1051b0568 0x104a68000 + 7636328
10 Toggl Track 0x1051aff44 0x104a68000 + 7634756
11 Toggl Track 0x1051b2848 0x104a68000 + 7645256
12 Toggl Track 0x1051dc6b4 0x104a68000 + 7816884
13 Toggl Track 0x1051d0af4 0x104a68000 + 7768820
14 Toggl Track 0x104c74768 0x104a68000 + 2148200
15 Toggl Track 0x104ce19a8 0x104a68000 + 2595240
16 Toggl Track 0x104a6a6ac 0x104a68000 + 9900
17 Toggl Track 0x104a6a7e0 0x104a68000 + 10208
18 CoreFoundation 0x189bb964c CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER + 148
19 CoreFoundation 0x189c45abc ___CFXRegistrationPost_block_invoke + 92
20 CoreFoundation 0x189c45a00 _CFXRegistrationPost + 440
21 CoreFoundation 0x189b88170 _CFXNotificationPost + 740
22 Foundation 0x18b3bc4a4 -[NSNotificationCenter postNotificationName:object:userInfo:] + 88
23 AppKit 0x18dfe2388 -[NSApplication finishLaunching] + 248
24 AppKit 0x18e1faef4 _NSApplicationBeginRunning + 184
25 AppKit 0x18dfe2048 -[NSApplication run] + 124
26 AppKit 0x18dfba7b0 NSApplicationMain + 880
27 Toggl Track 0x104a6a408 0x104a68000 + 9224
28 dyld 0x18974bda4 start + 6992
Thread 1:
Thread 2:: Dispatch queue: swiftybeaver-queue-BF64F574-0872-4CA9-A37A-356147FBD708
0 libicucore.A.dylib 0x18d821528 icu::RegexMatcher::find(UErrorCode&) + 1548
1 Foundation 0x18b408550 -[NSRegularExpression(NSMatching) enumerateMatchesInString:options:range:usingBlock:] + 692
2 Foundation 0x18b439c60 -[NSRegularExpression(NSMatching) matchesInString:options:range:] + 180
3 Foundation 0x18b446c48 -[NSRegularExpression(NSReplacement) stringByReplacingMatchesInString:options:range:withTemplate:] + 140
4 Foundation 0x18b4c2858 -[NSString(NSRegularExpressionSupport) _stringByReplacingOccurrencesOfRegularExpressionPattern:withTemplate:options:range:] + 220
5 Foundation 0x18bd68ecc StringProtocol.replacingOccurrences<A, B>(of:with:options:range:) + 544
6 Toggl Track 0x10511cee0 0x104a68000 + 7032544
7 Toggl Track 0x10512017c 0x104a68000 + 7045500
8 Toggl Track 0x105130be0 0x104a68000 + 7113696
9 Toggl Track 0x104a8e70c 0x104a68000 + 157452
10 libdispatch.dylib 0x18994ca28 _dispatch_call_block_and_release + 32
11 libdispatch.dylib 0x1899664b0 _dispatch_client_callout + 16
12 libdispatch.dylib 0x189955030 _dispatch_lane_serial_drain + 740
13 libdispatch.dylib 0x189955b2c _dispatch_lane_invoke + 392
14 libdispatch.dylib 0x18995fe34 _dispatch_root_queue_drain_deferred_wlh + 284
15 libdispatch.dylib 0x18995f734 _dispatch_workloop_worker_thread + 720
16 libsystem_pthread.dylib 0x189b03ec0 _pthread_wqthread + 292
17 libsystem_pthread.dylib 0x189b02c10 start_wqthread + 8
Thread 3:
Thread 4:: Dispatch queue: swiftybeaver-queue-9C3BB856-0CF9-4A08-A2DB-45B17982CCF9
0 Foundation 0x18b3f603c -[NSFileAccessClaim _setupWithClaimID:purposeID:originatingReactorQueueID:] + 0
1 Foundation 0x18b3f6008 -[NSFileAccessClaim initWithClient:claimID:purposeID:] + 132
2 Foundation 0x18b4c5d10 -[NSFileWritingClaim initWithPurposeID:url:options:claimer:] + 48
3 Foundation 0x18b4c78a8 -[NSFileCoordinator(NSPrivate) _coordinateWritingItemAtURL:options:error:byAccessor:] + 452
4 Foundation 0x18b4c76bc -[NSFileCoordinator coordinateWritingItemAtURL:options:error:byAccessor:] + 112
5 Toggl Track 0x105122960 0x104a68000 + 7055712
6 Toggl Track 0x105122264 0x104a68000 + 7053924
7 Toggl Track 0x105121aa4 0x104a68000 + 7051940
Thread 5:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x189ac3c34 mach_msg2_trap + 8
1 libsystem_kernel.dylib 0x189ad6574 mach_msg2_internal + 76
2 libsystem_kernel.dylib 0x189acc9c0 mach_msg_overwrite + 480
3 libsystem_kernel.dylib 0x189ac3fc0 mach_msg + 24
4 CoreFoundation 0x189bc4d68 __CFRunLoopServiceMachPort + 160
5 CoreFoundation 0x189bc3654 __CFRunLoopRun + 1188
6 CoreFoundation 0x189c95be0 _CFRunLoopRunSpecificWithOptions + 532
7 AppKit 0x18e110c64 _NSEventThread + 184
8 libsystem_pthread.dylib 0x189b07c58 _pthread_start + 136
9 libsystem_pthread.dylib 0x189b02c1c thread_start + 8
Thread 6:
Thread 7:
0 libsystem_kernel.dylib 0x189ac7308 __semwait_signal + 8
1 libsystem_c.dylib 0x1899a3cc0 nanosleep + 220
2 libsystem_c.dylib 0x1899ace24 sleep + 52
3 Toggl Track 0x105b0b308 0x104a68000 + 17445640
4 libsystem_pthread.dylib 0x189b07c58 _pthread_start + 136
5 libsystem_pthread.dylib 0x189b02c1c thread_start + 8
Thread 8:: SentryCrash Exception Handler (Secondary)
4 Toggl Track 0x105af4d94 0x104a68000 + 17354132
5 libsystem_pthread.dylib 0x189b07c58 _pthread_start + 136
6 libsystem_pthread.dylib 0x189b02c1c thread_start + 8
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000a49da9c08 x1: 0x0000000200000003 x2: 0x0000000000000060 x3: 0xfffff0007fc00000
x4: 0x00000004e1d15c13 x5: 0x0000000000000013 x6: 0x0000000000000020 x7: 0xfffff0007ffff800
x8: 0xfffffffe00000000 x9: 0x000000007fbfdfff x10: 0x00000001067e3060 x11: 0x0000000000000001
x12: 0x0000400180402000 x13: 0x0000300000401c00 x14: 0x0000000000002000 x15: 0x000000000000009d
x16: 0x0000000200000003 x17: 0x0000000000000003 x18: 0x0000000000000000 x19: 0x0000000a4ba4cb40
x20: 0x000000016b392828 x21: 0x0000000000000000 x22: 0x0000000a4abddf20 x23: 0x0000000a49cfc630
x24: 0x00000001f8714110 x25: 0x00000001f8714458 x26: 0x00000001f870a5b8 x27: 0x00000001f870da30
x28: 0x0000000a4b81e0a0 fp: 0x000000016b3927d0 lr: 0x000000019d2f3cc8
sp: 0x000000016b392750 pc: 0x000000019d2f3cc8 cpsr: 0x60000000
far: 0x0000000000000000 esr: 0xf2000001 (Breakpoint) brk 1
Binary Images:
0x104a68000 - 0x105dbffff com.toggl.daneel (10.16.0) <991add4a-57a5-33e5-86ad-6789eb3db950> /Applications/Toggl Track.app/Contents/MacOS/Toggl Track
0x106398000 - 0x1063a3fff libobjc-trampolines.dylib () /usr/lib/libobjc-trampolines.dylib
0x19d193000 - 0x19d73493f libswiftCore.dylib () /usr/lib/swift/libswiftCore.dylib
0x1915f0000 - 0x1919ddf5f com.apple.CoreData (120) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x189b47000 - 0x18a0a4c5f com.apple.CoreFoundation (6.9) <04941709-2330-3bf8-9213-6d33964db448> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x18b3b3000 - 0x18c3951df com.apple.Foundation (6.9) <8e9a5c62-7e95-3047-81e7-735ae1aee5f8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x18dfb6000 - 0x18f6d8abf com.apple.AppKit (6.9) <59e23bd5-d01e-305a-b96f-a5790356049a> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x18972c000 - 0x1897d1ec7 dyld () <9f682dcf-340c-3bfa-bcdd-dd702f30313e> /usr/lib/dyld
0x0 - 0xffffffffffffffff ??? () <00000000-0000-0000-0000-000000000000> ???
0x18d806000 - 0x18dadbd33 libicucore.A.dylib () /usr/lib/libicucore.A.dylib
0x18994b000 - 0x18999223f libdispatch.dylib () /usr/lib/system/libdispatch.dylib
0x189b01000 - 0x189b0db3b libsystem_pthread.dylib () /usr/lib/system/libsystem_pthread.dylib
0x189ac3000 - 0x189b0028f libsystem_kernel.dylib () <51565b39-f595-3e96-a217-fef29815057a> /usr/lib/system/libsystem_kernel.dylib
0x189996000 - 0x189a16ef7 libsystem_c.dylib (*) <66ebd321-6899-3863-ba24-5cfc3076a0cb> /usr/lib/system/libsystem_c.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
