Hello!
In the desktop app the space below the Goals dropdown seems unused and could be perfect for pinned / custom tasks:
What I mean with pinned tasks is, for example, I have a meeting that is the same name, tag and client each day that I would like to place there and just one-click start it. Currently it does populate from the dropdown that pops up when you start writing the task name but it is slow. Also sometimes a common task does not appear on that popup dropdown.
Would it be possible to create the same component as the Goals but for these custom tasks where you can define name, tags and client and then just one-click to start the task?
Cheers!
