"Projects" Endpoints - GET Get workspace projects users
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/project_users
List all projects users for a given workspace.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::GET, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/project_users".to_string())  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
Query​
project_ids string false Numeric IDs of projects, comma-separated
user_id string false Numeric ID of user, if passed returns only project users for this user’s projects
with_group_members boolean false Include group members
items Array of object -
items​
at string When was last modified
gid integer Group ID, legacy field
group_id integer Group ID
id integer Project User ID
labor_cost number null
labor_cost_last_updated string Date for labor cost last updated
manager boolean Whether the user is manager of the project
project_id integer Project ID
rate number null
rate_last_updated string Date for rate last updated
user_id integer User ID
Possible error messages:
  • Workspace not found
  • project_ids cannot exceed 200 elements.
  • Invalid user_id
