“Projects” Endpoints POST Workspace Projects
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/projects
Create project for given workspace.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::POST, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/projects".to_string()).json(&serde_json::json!(\{"active":"boolean","auto_estimates":"boolean","billable":"boolean","cid":"integer","client_id":"integer","client_name":"string","color":"string","currency":"string","end_date":"string","estimated_hours":"integer","fixed_fee":"number","is_private":"boolean","is_shared":"boolean","name":"string","rate":"number","rate_change_mode":"string","recurring":"boolean","recurring_parameters":\{"custom_period":"integer","period":"string","project_start_date":"string"\},"start_date":"string","template":"boolean","template_id":"integer"\}))  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
Body​
active boolean Whether the project is active or archived
auto_estimates boolean Whether estimates are based on task hours, optional, premium feature
billable boolean Whether the project is set as billable, optional, premium feature
cid integer Client ID, legacy
client_id integer Client ID, optional
client_name string Client name, optional
color string Project color
currency string Project currency, optional, premium feature
end_date string End date of a project timeframe
estimated_hours integer Estimated hours, optional, premium feature
fixed_fee number Project fixed fee, optional, premium feature
is_private boolean Whether the project is private or not
is_shared boolean Shared
name string Project name
rate number Hourly rate, optional, premium feature
rate_change_mode string Rate change mode, optional, premium feature. Can be “start-today”, “override-current”, “override-all”
recurring boolean Project is recurring, optional, premium feature
recurring_parameters object Project recurring parameters, optional, premium feature
start_date string Start date of a project timeframe
template boolean Project is template, optional, premium feature
template_id integer Template ID, optional
recurring_parameters​
custom_period integer Recurring custom period, the “period” field must be “custom”
period string Recurring period, example “monthly”
project_start_date string Recurring start date
actual_hours integer null
actual_seconds integer null
at string Last updated date
auto_estimates boolean null
billable boolean null
can_track_time boolean -
cid integer Client ID legacy field
client_id integer null
color string Color
created_at string Creation date
currency string null
current_period object Current project period, premium feature
estimated_hours integer null
fixed_fee number Fixed fee, premium feature
id integer Project ID
is_shared boolean Shared Project
name string Name
permissions string -
pinned boolean -
rate_last_updated string null
recurring boolean Whether the project is recurring, premium feature
recurring_parameters Array of object Project recurring parameters, premium feature
shared_at string -
shared_hash string -
status string Status of the project (upcoming, active, ended, archived, deleted)
tasks_count integer -
template boolean null
template_id integer null
wid integer Workspace ID legacy field
current_period​
end_date string -
start_date string -
custom_period integer Custom period, used when “period” field is “custom”
estimated_seconds integer Estimated seconds
parameter_end_date string null
parameter_start_date string Recurring start date
period string Period
project_start_date string Project start date
