Recurring Projects
Find out how to set recurring periods and create repeating estimates for your projects.
Projects can have their “Project Time Estimate” and “Task Time Estimates” reset based on the schedule of your choice with Recurring Projects. This is a Starter plan feature.
How to set up a Recurrence
Recurrences can be set up while creating a new project or editing an existing one. Enable the switch next to Recurring and under it choose the recurring period and date when you wish to start the recurrences from. If you set a Project End Date, the recurrences will end on that date automatically.
You can select a recurring period that is Weekly, Biweekly (2 weeks), Monthly, Quarterly (3-months), or Yearly.
Create project modal
Viewing Recurrences
On the Projects page, Projects with recurrences will be shown with a recurring icon next to them.
Reporting
The Tasks and Dashboard tab inside the Project will show you data from the current period by default, but you can scroll to see previous periods as well using the date selector at the top. The Project List and Tasks tab will still only show you data from the current period.
You can always view combined data from across periods under Reports.
Please note:
  • Recurrences do not create a new instance of the same project, it simply resets the estimates or fixed fee based on the schedule.
  • The Alerts feature will work with recurrences, and the email notification will mention that the alert is for a recurring project.
If you still have questions about Recurring Projects, please contact our Support team by clicking on the purple chat icon in the bottom right corner of this page to start a chat.
It would be great if there is an ability to set the budgeted hours per month when the flighting of those hours are not evenly distributed. For example, if I have a budget of 120 hours for a year long project, instead of 10 hours per month, maybe I want to plan for 20 in the first month and then about 9 hours each in the following month.
Hey @nlinn
Thanks for the feedback - I’ve sent it off to the team :slight_smile:
HI any update on this being an option?
Hi! I’m afraid there’s no ETA on this feature yet.
