Reports beta
I’m sorry but the beta for reports is horrible. I really find the previous(?) older reports to be so much better. As the org admin, I need to go and check through people’s project allocations because they often choose the wrong project. The new reports makes it so difficult to check, change, and return back to the same person in the same selections for time, format, etc. The old one made it delightfully easier!
In the new beta, any time you click on an entry, it takes you to a new screen but you cannot go back to the previous view. Very frustrating.
I agree. There are too many steps to get a filter - moving the cursor into different boxes, whereas previously you can use the keyboard and practically choose as shown. Hidden filters are pretty unwieldy. I have disabled Beta.
Yes, the new reports is massively worse than the previous one. If this is what Toggl thinks is an improvement, I need to make plans to use a different product.
Thank you all for your feedback! It has been shared with the product team and we hope to better meet your needs once the new reports are out of beta.
