"Summary report" Endpoints - POST Load project summary
https://api.track.toggl.com/reports/api/v3/workspace/{workspace_id}/projects/{project_id}/summary
Returns project’s summary.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::POST, "https://api.track.toggl.com/reports/api/v3/workspace/{workspace_id}/projects/{project_id}/summary".to_string()).json(&serde_json::json!(\{"end_date":"string","startTime":"string","start_date":"string"\}))  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
workspace_id integer true Workspace ID
project_id integer true Project ID
Body​
end_date string End date, example time.DateOnly. Should be greater than Start date.
startTime string -
start_date string Start date, example time.DateOnly. Should be less than End date.
Returns project summary
billable_amount_in_cents integer -
graph Array of object -
labour_cost_in_cents integer -
rates Array of object -
resolution string -
seconds integer -
tracked_days integer -
graph​
by_rate object -
seconds integer -
by_rate​
rates​
billable_seconds integer -
currency string -
hourly_rate_in_cents integer -
Possible error messages:
  • Invalid workspace id
  • Invalid project id
  • The {parameter} parameter is required
  • Invalid {parameter} format
  • {date_range} should be within 2006-01-01 to 2030-01-01
402​
Workspace needs to have the {feature} feature enabled
  • Workspace not found/accessible
  • project not found or not accessible
