https://api.track.toggl.com/reports/api/v3/workspace/{workspace_id}/projects/summary
Returns summary user projects.
- cURL
- Go
- Ruby
- JavaScript
- Python
- Rust
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> { let client = Client::new().basic_auth("<email>", "<password>"); let json = client.request(Method::POST, "https://api.track.toggl.com/reports/api/v3/workspace/{workspace_id}/projects/summary".to_string()).json(&serde_json::json!(\{"end_date":"string","startTime":"string","start_date":"string"\})) .header(CONTENT_TYPE, "application/json") .send() .await? .json() .await?; println!("{:#?}", json); Ok(())}
Parameters
Path
| workspace_id | integer | true | Workspace ID |
Body
| Name | Type | Description |
| end_date | string | End date, example time.DateOnly. Should be greater than Start date. |
| startTime | string | - |
| start_date | string | Start date, example time.DateOnly. Should be less than End date. |
Response
200
| items | Array of object | - |
items
| billable_seconds | integer | - |
| project_id | integer | - |
| tracked_seconds | integer | - |
| user_id | integer | - |
400
Possible error messages:
- At least one parameter must be set
- Invalid workspace id
500
