"Tasks" Endpoints - GET Workspace Project Task via ID
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/projects/{project_id}/tasks/{task_id}
Get project task for given task id.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::GET, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/projects/{project_id}/tasks/{task_id}".to_string())  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
project_id integer true Numeric ID of the project
task_id integer true Numeric ID of the task
active boolean False when the task has been done
at string When the task was created/last modified
client_name string null
id integer Task ID
name string Task Name
permissions string -
project_billable boolean -
project_color string Metadata
project_id integer Project ID
project_name string -
rate number Rate for this task
rate_last_updated string null
recurring boolean Whether this is a recurring task
toggl_accounts_id string null
tracked_seconds integer The value tracked_seconds is in milliseconds, not in seconds.
user_id integer null
Possible errors:
  • Invalid project_id
  • Invalid task_id
