https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/projects/{project_id}/tasks
Get project tasks for given workspace.
- cURL
- Go
- Ruby
- JavaScript
- Python
- Rust
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> { let client = Client::new().basic_auth("<email>", "<password>"); let json = client.request(Method::GET, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/projects/{project_id}/tasks".to_string()) .header(CONTENT_TYPE, "application/json") .send() .await? .json() .await?; println!("{:#?}", json); Ok(())}
Parameters
Path
| workspace_id | integer | true | Numeric ID of the workspace |
| project_id | integer | true | Numeric ID of the project |
Response
200
| Name | Type | Description |
| active | boolean | False when the task has been done |
| at | string | When the task was created/last modified |
| client_name | string | null |
| estimated_seconds | integer | null |
| id | integer | Task ID |
| integration_ext_id | string | The external ID of the linked entity in the external system (e.g. JIRA/SalesForce) |
| integration_ext_type | string | The external type of the linked entity in the external system (e.g. JIRA/SalesForce) |
| integration_provider | string | The provider (e.g. JIRA/SalesForce) that has an entity linked to this Toggl Track entity |
| name | string | Task Name |
| permissions | string | - |
| project_billable | boolean | - |
| project_color | string | Metadata |
| project_id | integer | Project ID |
| project_name | string | - |
| rate | number | Rate for this task |
| rate_last_updated | string | null |
| recurring | boolean | Whether this is a recurring task |
| toggl_accounts_id | string | null |
| tracked_seconds | integer | The value tracked_seconds is in milliseconds, not in seconds. |
| user_id | integer | null |
| workspace_id | integer | Workspace ID |
400
Possible errors:
- Invalid project_id
403
500
