Timer page
the timer page used to show the last 3 months (90 days) of data, but since the change to “calendar, list view, timesheet”, the only options are now “today, yesterday, this week and last week”. To see anything more, you have to go to reports.
the “assistant” still indicates the 90 day view, but I cannot figure out how to get it.
I find jumping from the timer page to the reports very inconvenient when i am trying to duplicate a task for another day, that happened to be last week or the week before.
Please advise.
:bulb: Helpful Tips for Best Answers:
  • Be clear and concise.
  • Check if your question has been asked before. :mag:
  • Be respectful and thank those who help. :slight_smile:
Head over to the Product Feedback forum, you sure aren’t the only one who isn’t happy with this stupid change.
Thank you for reaching out about the timer page changes. I understand this feels like a significant shift from what you’re used to.
Let me clarify what’s changed:
Previously, the timer page would automatically display the last 90 days of data without requiring any date selection. Now, the timer page defaults to showing a weekly view, but you still have full access to your data.
Here’s how it works now:
  • The default view shows the past 7 days for list view
  • You can use the new date picker to select custom date ranges of up to 30 days, or move between the weeks using the arrows in the date range picker
  • You can still access data going back 90 days by selecting different date ranges (up to 30 days at a time)
We understand this is a change from the previous “show everything” approach, and we appreciate your feedback about how these changes affect your workflow.
Please let me know if you have any other questions about navigating the updated timer page.
Even if you change it to 30 days, for some reason it reverts to “this week” within the day and you have to change it again and again. Instead of one simple click on “Load more” (as it was before) you need to click on data picker and play with it every time. That’s frustrating.
Just add an option (that persists and doesn’t reset) to see the last 90 days once again and everyone will be happy.
