Toggl 2.o down?
Hi All,
Is Toggl -specifically Toggl2 - down? The app gives me an unresponsive blank window, when I go to the login page for Toggl 2, it’s also just a white screen. The phone app seems to work, although it’s not the easiest to use (especially for logging time entries in the past).
Anyone else having this issue?
Sorry to hear you’re running into this! A blank or unresponsive screen can be frustrating, especially when you need to log time.
A few things worth trying that often resolve this kind of issue:
  • Try clearing your browser cache and cookies, then reload the page
  • Try a different browser to see if the issue is browser-specific
  • Disable any browser extensions that might interfere with page loading
  • Try opening the page in a private/incognito window
If others in the community are seeing the same thing right now, it would be helpful to know so you can get a sense of whether this is widespread. You can also check togglplan.statuspage.io to see if there are any reported incidents or outages affecting the service.
are you using Safari on mac?
Sounds like the same Issue Im having.
No, I’m using Firefox on Mac, but I also get the same with the app - it’s just a white window.
Hey all! Can you attempt to open Toggl 2.0 in an Incognito window, making sure you’re allowing cookies just to check?
Same result - blank (white) screen and the app doesn;t work. I have shut down a couple of times and my computer automatically clears cache and cookies.
Let me email you about this :slight_smile:
