We recently noticed that Toggl favourites are being removed from Toggl Track? Has anyone else experienced this, and if so, how can we fix? ![]()
We are aware of the issue and are currently fixing it. I will provide updates here when it is resolved. Thank you for your patience! ![]()
Hey @Stephanie, the issue should be resolved. A fix went out this week, and the new version of the web app should have reached you by now. Can you please confirm that all is good?
Hi - for me the problem is NOT fixed - and I see from posts in other threads it’s not just me. The favorites bar disappeared a few days ago and has not returned. I can now only see my favorites in the drop down menu but that’s all. I can add favorites but cannot remove any! Please let me know the fix ASAP. TYVM. MM
We have just released an update to the Timer page
You can now locate the Goals and Favourites under this button:
..or by clicking on the time entry description field at the top of the Timer page.
Don’t hesitate to share any further questions or feedback on the new Timer page with us!
Thanks very much Diane. It works, plus I can remove favourites - yay! But some more feedback for you. As I don’t want the goals/favourites bar always present, it’s now 3 clicks to select a favourite rather than the previous 1 click from the previously always-present favourites ribbon. I fear the new fix is a backwards step as favourites, by definition, should be quick to access. I’ll get used to it, I expect :-). MM
Thanks for the honest feedback @Muir_Macdonald
I’ll be sharing your comment with the product team. ![]()
