Turns out I've got two timesheets?!
Toggl
Topic content
I have no idea how this has happened… for a while I’ve noticed something was off - I don’t invoice some clients that regularly and I felt like some time was disappearing but couldn’t figure out what was happening, but now I’ve just discovered I have two entirely different records of my time on two systems that look identical…
One is on https://track.toggl.com/
and the other on https://focus.toggl.com/
Can someone tell me how this has happened, why, what to do about it… can I merge them together? Honestly this is both confusing but I am also going to have to invoice some clients an additional amount and explain that due to some error I can’t even explain I missed a load of their time logs.
EDIT: OK I have just been through both timesheets and downloaded the data from both, sorted in in Excel and compared the two and although the sheets *display* differently, for some clients there’s no difference, but for one - whose work I’ve been doing a lot of this week - there is. Is that because they haven’t synced yet? Will they sync? When does that happen?
I assume this is from logging in on different browsers that autofill when I type “togg…” and then go to either Focus or Track.
Frankly this is not really an agreeable situation and has taken hours to sort out and been quite stressful thinking I would need to be invoicing clients for additional hours.
Exactly which one should I be using? And is there a way to permanently disable the other one?
What you’ve discovered is that track.toggl.com and focus.toggl.com are actually two separate products made by the same company - Toggl Track and Toggl (formerly known as Toggl Focus). They are not the same thing, they do not share time entry data, and they will not sync with each other. The different display you’re seeing is not a sync delay - those are genuinely two separate records on two separate systems.
It sounds like your browser autocomplete has been splitting your logins between the two URLs over time, which is how entries have ended up in both places.
To answer your direct questions:
There is no way to merge data between the two products. They are entirely separate.
Which one you should use is a matter of which you prefer. Toggl Track lives at track.toggl.com and is the dedicated time tracking product. Toggl at focus.toggl.com is a combined planning and time tracking tool. If your primary need is straightforward time tracking and invoicing, Toggl Track is the more focused option for that.
To avoid this happening again, the practical fix is to remove the focus.toggl.com entry from your browser’s autocomplete so you always land on the one you intend to use. Going forward, log in only to the one you choose and ignore the other.
I’m sorry this has caused you stress and extra reconciliation work - discovering split records unexpectedly like that is genuinely frustrating.
Yep, me too! I finally figured it out. This community was not very helpful, but contacting support chat helped. But ultimately, I had to sort this all out on my own. This software upgrade was such a cluster for customers! BTW, I heard they will retire Toggl Track soon.
