I have 2 calendars synced to my Toggl. Basically every personal event is marked as “Out of office” in my work calendar and this creates crazy visual clutter. I cannot remove these events from my primary calendar because it wouldn’t be visible to colleagues/Slack etc. and I also cannot use extensions with my work account.
Could it be possible to add a toggle feature that filters out “Out of office” events? For example, Slack updates status as OOO if an event has “OOO/PTO/Out of office” included in the title, so something along the lines - don’t show an event if it’s implied it’s OOO
That’s a great idea, and I can see how those “Out of Office” events would create a lot of visual noise when you’re trying to track your actual work.
Currently, Toggl does not have a way to filter out specific event types or events by keyword from the calendar view. The matching rules feature under Settings → Connected calendars → Matching rules lets you assign tasks, projects, tags, and billable status to events based on keywords, but it doesn’t offer a way to hide or exclude events entirely.
The closest workaround would be to selectively enable or disable individual calendars in Settings → Connected calendars, but that’s an all-or-nothing approach per calendar rather than filtering at the event level, which doesn’t solve your situation since the OOO events live in the same calendar as your real work events.
I’ll pass your suggestion along to the product team - keyword-based filtering to suppress certain event types from appearing would be a useful addition.
