Ability to add tags to projects and tasks
We would very much like the ability to add tags to projects and tasks, so they will automatically be set on all time entries on that project or task.
Ideally the logic should be such that if there is a tag on a project, then all entries on the project should get that tag UNLESS there is a tag on the task, then the “task tag” should overwrite the the tag set on the project.
Finally if the user select a specific tag for a time entry it should overwrite/adjust any tags coming from the project or task
Hi! I’ll share this with our team :slight_smile:
hello! any update on this request? I’m running into the same issue - with dozens of projects, having to manually add the tag each time feels needlessly tedious.
I would also like this function
