Add a "no timezone" option?
I’m traveling a lot for work and doing a lot of remote work for clients. I want my time entries to basically be “local” time. For example, right now, I’m in Portland, OR, but I live in NYC. However, in 2 weeks, I’ll be in Mountain time, then back in EST. Having all of my entries showing as Eastern when I’m not currently there is very confusing. I also don’t want to have to change it every week or two.
I understand the challenge with frequent timezone changes for remote work. Unfortunately, Toggl doesn’t currently have a “no timezone” option that would let you keep time entries in local time regardless of where you are.
What you can do as a workaround is manually update your timezone in your Toggl account settings whenever you move to a new location. While this does require periodic updates, it ensures your time entries are recorded in your current local time.
For frequent travelers like yourself who work across multiple timezones, this is a feature request worth considering. The ability to have entries stay in local time without timezone conversion would definitely make tracking simpler for your situation.
