Toggl
Topic content
Why does “Start Timer” have that 2-second pause?
I previously used Toggl Track, now am using the “new and improved” Toggl.
There is one super annoying part of it. Whenever you start a new activity and the timer starts automatically, there is this countdown for it to actually start. Clicking it doesn’t start it if the countdown has already started, and navigating away to another window stops the countdown. I haven’t found a way to fix this.
So every time I start an activity I have this annoying 2-3 second wait for the tracker to finish the countdown.
Surely this must be unnecessary? I’ve been searching in settings for a way to fix it, but no luck so far…
pls help Toggl team!
The countdown you’re seeing is a built-in feature of Toggl’s timer bar. When you type a description, a five-second countdown begins automatically before the timer starts. During that window, you can press Enter or click the play button to start it immediately without waiting for the countdown to finish.
If clicking the play button isn’t working for you once the countdown has begun, that does sound like unexpected behavior worth noting. The intended way to skip the wait is to press Enter straight away after typing your description.
There is not currently a setting to disable the countdown entirely. That said, using Enter to kick off the timer immediately should save you that 2-3 second wait each time.
