Asana Toggl Integration No Longer Passing Project Names Automatically
For about a week now, my Asana Toggl integration has stopped transferring project names to Toggl. Previously, clicking the Toggl button in the Asana web app would automatically populate both the task name and the project name in the Toggl desktop app — no manual input needed.
Now, after clicking the Toggl button in Asana, I have to manually select my project every single time. The task name still transfers, but the project name does not.
Has anyone else experienced this recently? Could this be a bug introduced in a recent update to either the Asana or Toggl integration? Any fix or workaround would be greatly appreciated!
I understand how frustrating it is when an integration that was working smoothly suddenly requires manual work. Unfortunately, the knowledge base articles available don’t contain specific troubleshooting steps for this Asana integration issue.
Since this is affecting the automatic project name transfer from Asana while task names still come through, here are a few things you can try:
First, try disconnecting and reconnecting the Asana integration. This often resolves sync issues with third-party app connections.
You could also check if there have been any recent changes to your Asana account permissions or project settings that might affect how the integration accesses project information.
If the issue persists after trying these steps, it would be worth checking whether your Asana and Toggl apps are fully up to date, as integration bugs are sometimes resolved in updates.
For a more detailed investigation into what’s causing this specific behavior, the Toggl support team would be able to look into your account and the integration logs to identify whether this is a known issue or something specific to your setup.
