Bulk edit of time entries returns error when trying to change project
Toggl
Topic content
I’m consistently encountering an error when I try to bulk edit the project associated with time entries, which reads “X selected entries across Y tasks will keep their project.” Anyone have any idea why I cannot use the bulk edit feature to edit the projects that time entries are assigned to?
The error message you’re seeing - “X selected entries across Y tasks will keep their project” - points to a specific limitation with bulk editing time logs in Toggl.
When a time log is linked to a task, the project is inherited from that task and cannot be overridden independently. So if any of the entries you’ve selected are attached to tasks, those entries will keep whichever project the task belongs to, and the bulk edit cannot reassign them to a different project.
The workaround for those entries would be to first remove the task association from the time logs individually, and then attempt the bulk project change. Alternatively, if the goal is to move the work to a different project, you may need to reassign the underlying tasks themselves to the new project, which would carry the time logs with them.
For entries that are not linked to a task, the bulk project edit should work without issue.
