Changing available work hours won't update capacity
I have changed my work hours to 5 hours a day in settings. the capacity tracker in timeline is still stating 8 hours available a day.
I’ve tried refreshing and opening a new browser. It worked before but won’t update.
Any help would be appreciated! Thank you.
Hello! Is this in Toggl Focus?
Hi - yes it is. I’ve change the hours to “custom” under work focus to 5 hours a day. The little green pop up said is has saved. I then switch to “timeline” and it still says 8 hours a day.
Thanks for confirming @emsyD looking into this for you.
Thanks so much! Looking forward to hearing from you.
