When starting with Toggl last year, I entered my “work hours” in the calendar view, as mentioned in this article, so that I get the tracked hours compared with them, as a percentage. Now, the amount of hours I work has changed, so the percentage is no more accurate. However, I struggle to find the option to update the weekly hours, or at least to remove them.
Did anybody have the same issue and found the corresponding settings?
In case that might be useful info, I´m on the free plan.
Hey @katonthetrack
If you click the cog icon on the timer page when on the calendar view you can choose your calendar hours:
Hope this helps!
Hi Diane, thank you for your reply. Unfortunately, that doesn´t solve the issue. The issue I am encountering is due to the fact that previously I have entered 20h as the amount of my weekly working hours. Now, if I work more and track more accordingly, the percentage is over 100. I´ve attached the screenshot.
Maybe you have any idea, how I can update the “goal” amount of hours or remove the option of displaying the tracked hours in a percent equivalent?
Best wishes,
Kat
