https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/clients
List clients from workspace.
- cURL
- Go
- Ruby
- JavaScript
- Python
- Rust
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> { let client = Client::new().basic_auth("<email>", "<password>"); let json = client.request(Method::GET, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/clients".to_string()) .header(CONTENT_TYPE, "application/json") .send() .await? .json() .await?; println!("{:#?}", json); Ok(())}
Parameters
Path
| workspace_id | integer | true | Numeric ID of the workspace |
Query
| status | string | false | Use ‘active’ to only list active clients, ‘archived’ to only list archived clients and ‘both’ to retrieve active and archived clients. If not provided, only active clients are returned. |
| name | string | false | If provided, allows to filter by client name in a case insensitive manner, returning all the ones that contain the given string. |
Response
200
| Name | Type | Description |
| items | Array of object | - |
items
| archived | boolean | IsArchived is true if the client is archived |
| at | string | When was the last update |
| creator_id | integer | CreatorID is the ID of the user who created the client |
| id | integer | Client ID |
| integration_ext_id | string | The external ID of the linked entity in the external system (e.g. JIRA/SalesForce) |
| integration_ext_type | string | The external type of the linked entity in the external system (e.g. JIRA/SalesForce) |
| integration_provider | string | The provider (e.g. JIRA/SalesForce) that has an entity linked to this Toggl Track entity |
| name | string | Name of the client |
| notes | string | - |
| permissions | string | List of authorization permissions for this client. |
| wid | integer | Workspace ID |
400
Client status is invalid
403
Forbidden
500
