"Clients" Endpoints - POST Create client
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/clients
Create workspace client.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::POST, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/clients".to_string()).json(&serde_json::json!(\{"name":"string","notes":"string","wid":"integer"\}))  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
Body​
name string Client name
notes string -
wid integer Workspace ID
archived boolean IsArchived is true if the client is archived
at string When was the last update
creator_id integer CreatorID is the ID of the user who created the client
id integer Client ID
name string Name of the client
notes string -
permissions string List of authorization permissions for this client.
Possible error messages:
  • Client name maximum length is {max_client_length}
  • Client name cannot be empty
Forbidden
