https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/clients/{client_id}
Update workspace client.
Note: use /workspaces/{workspace_id}/clients/{client_id}/archive to archive the client and /workspaces/{workspace_id}/clients/{client_id}/restore to restore it.
- cURL
 - Go
 - Ruby
 - JavaScript
 - Python
 - Rust
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::PUT, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/clients/{client_id}".to_string()).json(&serde_json::json!(\{"name":"string","notes":"string","wid":"integer"\}))  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
Parameters
Path
| workspace_id | integer | true | Numeric ID of the workspace |
| client_id | integer | true | Numeric ID of the client |
Body
| Name | Type | Description |
| name | string | Client name |
| notes | string | - |
| wid | integer | Workspace ID |
Response
200
| archived | boolean | IsArchived is true if the client is archived |
| at | string | When was the last update |
| creator_id | integer | CreatorID is the ID of the user who created the client |
| id | integer | Client ID |
| integration_ext_id | string | The external ID of the linked entity in the external system (e.g. JIRA/SalesForce) |
| integration_ext_type | string | The external type of the linked entity in the external system (e.g. JIRA/SalesForce) |
| integration_provider | string | The provider (e.g. JIRA/SalesForce) that has an entity linked to this Toggl Track entity |
| name | string | Name of the client |
| permissions | string | List of authorization permissions for this client. |
400
Possible error messages:
- Client name maximum length is {max_client_length}
 - Client name cannot be empty
403
Forbidden
404
Client doesn’t exist in the workspace.
500
