add an option to customize the character used between tags when exporting
@ariella.feldman thanks for asking
Can you please clarify your request? Are you referring to a CSV export of raw data?
yup, CSV or XLSX! when exporting data to a file, the character that Toggl uses between tags is a comma. one of my tags has commas in it, so a more unique character would improve efficiency when using text>column delimiters to separate multiple tags on one item. thanks!
what would be best though, is an option in settings to select/customize the Tag delimiter for exporting.
this additional settings option would also solve the following thread, as an example:
Double Quotation Marks in Data Export - Ask the Community - Toggl Community
Thanks for the clarification @ariella.feldman ![]()
I’ll make sure to share this with our product team ![]()
