Default project per integration/domain
Hi,
One feature I find very convenient would be to set a default project per single integration or per single integration domain.
It happens very often to have a certain issue tracking system linked to a single customer/project.
Regards,
Diego
Hi Diego, :raised_hands:
Thanks for the suggestion! :toggl-heart2: Setting a default project per integration or domain is a great idea. I’ve shared it with the team for consideration and will keep you updated on any developments. :toggl-rocket:
Thank you Marie!
Regards,
Diego
Hello,
Is there any improvement on this?
When I start a timer from an integrated website (Azure DevOps), it creates a new time entry with the proper description, but no project is linked to it.
Is it possible to set a default project ?
