Exporting dates in ISO 8601 - yyyy-mm-dd format
The desktop version of TogglTrack shows the dates according to my locale, Australia, dd/mm/yyyy. The web version uses the US format, mm/dd/yyyy.
I use ISO Dates. yyyy-mm-dd.
In order of importance.
  1. How do I get reports to use ISO 8601 date format?
  2. How do I get the web app to use ISO 8601 date format?
  3. How do I get the desktop app to use ISO 8601 date format?
Cheers and thanks!
Keith
Heya Keith! You can attempt to check your My Profile Settings (Toggl Track) to ensure your date settings are what you wish them to be!
They are set to Australia/Adelaide which is correct.
The reports are using a US format which is wrong for Australia.
There is no setting to change the date format.
Any work arounds?
Cheers
Keith
Can you head down to “Time and Date” in the link shared above and verify that the “Date Format” setting there has YYYY-MM-DD set? This is separate from the “time zone” setting.
My mistake. Thank you.
