Goal progress indicator and completion state (IOS 26.2) BUG REPORT
There appears to be an issue with how daily goal progress and completion are represented in the Goals view.
  • For the goal “X”, set to “at least 1.5 hours every day”, the goal indicator does not visually reflect partial progress during the day. While time is being tracked under the linked project and tag, the goal row continues to show only the “Keep going” label, and the circle icon does not gradually fill as time accumulates.
  • Even after the total tracked time for that goal exceeds 1.5 hours (for example, multiple entries totalling more than 1:30:00 on the same day), the goal does not appear marked as completed for that day in the Goals section, and still shows “Keep going”.
Thank you in advance for looking into this.
I have resolved the issue with goal progress not updating.
The problem was resolved by not using automatic login via Google. Instead, logging in natively by creating a dedicated Toggl account fixed the connection between project time entries and goals. I feel like the issue might be connected how the google account communicate with database
