Goals for whole month and client
Hi, I discovered new Goals feature, but it is not suitable for me. I typically agree with the client on how many hours per month I will work for them.
So I would like to have possibility:
  • set “for” every month
  • set “Track” to client, because I have more projects for one client
Thanks!
We can log this feedback with the team :slight_smile: Thank you!
This is my exact use case as well, it would be great to be able to log at client-month level
This! I had no other use case for goals. My work cycle is basically in a monthly cadence. The first two weeks vary dramatically from the last two weeks. So, it only makes sense for me to set monthly goals.
I won’t get into why setting goals for clients is important. Just know that tracking by project isn’t very useful for me.
YES!!! I love the goals feature, but it only makes sense for me to do it by client, and my clients have multiple projects.
I use a work around by adding all projects for a certain client to the goal but then you have to start over from scratch when you add a project for that client, because goals can’t be edited.
I would really love to see this functionality also. I purely want to set the goal as, for example ‘13 hours for X client this week, Mon-Fri’. No project, no task, purely run down a clock on my hours with each client.
