Hours total for a in a report doesn't match Projects dashboard
Hello Toggl Community,
When looking at the same 4 projects first in a report and then in the Projects tab, the totals of the hours for each project don’t match. All projects started within the last 12 months and the report is also for the last 12 months.
Thank you for any help!
Hi Gilmour! I’ll be DM’ing you to get some specific info from ya :slight_smile:
Hi Jake, this is happening to me too. Can you share the fix? Thank you.
Hi Jake, this is happening to me as well. Hours I add in with my timer and my project totals hours don’t match.
I am having this issue as well. There are no sync errors visible, but recently the Time Status has stopped updating.
I think I’m also having this issue with Reports; Duration and Progress do not match.
@Jake , was there a fix from the investigation 4 months ago that you can share with me + the 3 folks above who commented on this in the last 3 days? Or should I post a fresh topic? Thank you for your help!
Projects>“Time status” is less than “Hours total” (when this project clicked). Vibe coding?
Hi all, thank you so much for taking the time to post about this! We are aware of the issue and are already working on a fix. The team is doing their best to roll out an update as soon as possible. Thank you for your patience, everyone. :raising_hands:
Thank you @Support and Toggl team for your response!
As of this morning, it looks like it has been fixed, or at least the specific issue I was concerned about. Contrast this progress bar with the one in my last comment:
Yep, all issues should be resolved, but please let me know if you come across anything else :slight_smile:
Hi, still not solved. I posted a similar issue here, I am not sure if it is what these guys were speaking about, though: Bug in reports?
Thanks!
@Antonio I’ll reach out via DM to get some more details from you so our team can investigate further.
Hi all,
This is still happening to me. For all my projects “Time status” and “Totals hours” don’t match.
Regards,
I’m reaching out to you via email :slight_smile:
