Toggl Track and Plan not syncing properly
Hi, I’ve used Toggl Track (free plan) for a while with no issues, and yesterday signed up for a Starter subscription to use Toggl Plan. I am using both within Chrome.
Within the Apps & Integration Setting in Toggl Plan, I had integration switched on, linked my workspace and set all three sync settings to on.
I spent a lot of time creating projects with timelines, segments and tasks, adding estimated time to projects, reassigning toggl track entries from the past couple of months to my newly organised projects, then deleting old projects.
Halfway through doing this, it didn’t seem to be syncing, so I went back into the Toggl Plan settings and noticed that ‘Sync tasks’ had changed back to ‘do not sync’. So I switched ‘integration’ off and on again and turned ‘Sync tasks’ back on.
This morning I just opened Toggl Track and Plan, and all the old projects that I deleted have reappeared in both Track and Plan, some of my project time estimates have disappeared, and ‘Sync Tasks’ has once again switched off by itself.
Another issue that I ran into is that for some of my newly-created projects, if I go into Progress within Plan and click through into the Report, it will show me a whole bunch of time entries within Toggl Track. However, if I go to the Projects list within Track, that same project shows a ‘Time Status’ of 0 h.
These issues are very frustrating and are wasting a lot of time. I’m hoping that they’re just teething problems, but if they persist I will need to cancel my subscription and find an alternative tool.
Is there anything I might be doing wrong?
Thanks
