How to change timer settings to 1 hour per cell?
How do I get back to seeing each cell in a timer as one hour instead of two?
It was so convenient, but now I can’t find a setting doing just that to the weekly view. Maybe anyone knows? Also, not having a support chat anymore is frustrating :frowning:
Looking at the weekly view in Toggl Track, you can adjust how the time is displayed by changing the cell size. In the weekly view, you should be able to zoom or adjust the granularity of the time cells. Check if there’s a zoom control or view settings option in your weekly calendar view that lets you change between displaying 1-hour or 2-hour blocks per cell.
The exact location of this setting may vary depending on whether you’re using Toggl Track on web or mobile, so look for any view adjustment options near your calendar display. If you’re having trouble locating it, try checking the settings or preferences within your app.
