How to add a second Passkey?
I enabled the Passkey authentication option in my account settings, then the Passkey popup came up in the browser on my Mac, I created the passkey and can now log in with the Passkey. Great!
But what about my work PC?
I can still log in with username & password on my work PC. But how do I create a Passkey for this machine? The Passkey authentication option is already enabled in my account settings, so how do I trigger the Passkey popup again to create another one?
I know that Passkeys can sync via iCloud for example, but I can’t use my private Mac iCloud account on my work PC, so I need to create a new Passkey. Also the idea of Passkeys is, that they are bound to the machine, so sharing a Passkey isn’t really intended.
Hi @Cheesekeeper, thanks for posting about this!
Indeed, there is no way to add a 2nd passkey at this time. Adding this as a feature request on our end. Would it be a viable workaround to use Google or a tool like 1Password across these devices and store the passkey there, considering your private iCloud is not an option?
Thank you for considering this a feature request!
I indeed use 1Password for sharing the Passkey now. It’s fine, but still I’d prefer to have a Passkey per machine, so I can invalidate it if one PC gets compromised. I’m looking forward to the future implementation of multiple Passkeys!
I’m in the same boat. I use Toggl on my iPhone, but since I already set up a passkey on my Windows desktop, I can’t create one for my phone. To work around, I’ve removed the windows one and set one up on my phone, but now I have to go through the awkward bluetooth connection process to get the phone to send the passkey to my desktop. It would be so much better to have multiple passkeys (not just two) so some can be revoked as needed, as Cheesekeeper mentioned.
