How to expand or collapse daily entries on Mac
Hello everyone
I use toggl for some years now, and mostly on linux and windows.
Now on the new company I’m using Mac, and could not find how to do two things I got used to:
  • when setting up lables and projects, diferentiate them by colors
  • how to toggle collapse and expando daily tracking, as now I’m tracking form some weeks the scrolling is quite big and as I do not have the right click to expand or collapse, I would like to know how to do it on the mac version
thanks everyone
Hello!
  • When creating a new project in the app, type in the new project’s name, then click “Create Project”. A popup will appear with a color icon to the right of the project name; you can select your project color there.
  • Are you looking to collapse entire days of entries?
yes, I used to work on windows, and I had this right click / collapse all, and was easy to do a quick look on the sum of hours of each day
now I cant do that, the entries are just a bit listing and hard to identify quickly
You can change the group items setting on the profile page: Toggl Track
Took me a while to find it on Mac as well!
So at this time we don’t formally have the same “collapse” option that the Windows app does, but I have shared this with our Product and Mac team to take into consideration!
not sure what you mean with this grouping, but yes I have similar entries grouped on the page, but I don`t see how the page configurations should relate to the appliation itself
That would be just awesome! :smiley:
I use the time tracking daily, but I usually collapse the previews entries so its easier for me to check if I need to stay a little longer to compensate days I did not clocked the whole 8 hours.
Also as a suggestion, on the app itself could be an option to highlight (even a short line would help) to see whole weeks, or when one ends and the next one starts.
I can see more detail on the site yes, but the timer is always there in hand and its easier then opening another browser just for this.
For now I`m no longer using the mac native app and running toggle on windows via RDP
Let me know if there is a proper page for suggestions, as my plans to subscribe went down as it became no longer ‘portable’ for me now that I`m on mac
If you’re OK with it, I can switch this over to our “Product Feedback” portion of the community, which essentially serves as our “Suggestion Box” :slight_smile:
