Integration with youtrack stopped working for me
Hello all.
I used the forum search but didn’t find any results for the word ‘youtrack’. It’s strange.
I’ve tested issue for Chrome and Firefox. With custom youtrack server and youtrack cloud.
For Linux and for MacOS. All grants and hostnames set correctly and works before.
Should we expect fixes? Maybe someone knows how to fix this?
I used the service for over 10 years, but now I was forced to migrate to another one. Integration is important to me. Still have subscription. If it might be important.
Thanks in advance for your answers.
Alex.
Hey,
The team are aware of this and have an open issue. I’ve added you to the issue and we’ll ping you when a fix is released :slight_smile:
Toggle Button was a killer-feature. It’s a shame it stopped working. It made toggl a hub. Since there are no integrations with developers’ IDEs. Thanks for these great years of work.
@ungewissheit Our developers still have this on the to-do list, we didn’t forget about you :slight_smile: Hope to be able to share an update soon!
The team has let us know that the issue with YouTrack is now fixed in the latest release of the browser extension: 4.11.3.
If you have not received this update yet please uninstall and reinstall the browser extension :blush:
Thanks!
Thank you for answer. I popped in to check if it was fixed. But no. Still does not works for me. I used a custom domain latest YouTrack 2025.3. I see no button (was broken early 2025).
But it works partitionally with cloud domain. The button appears in Agile.
The lack of integration forced me to migrate from service. After many years of use. Furthermore, there’s no integration with Android Studio or IntelliJ IDEA. This is very strange. I’m at a loss to understand why.
Best regards, Alex.
upd. MacOS, Linux. Chrome.
Hello! Can you share what version of the extension you are currently running?
Hello. Just installed Version 4.11.5
Thank you! Lemme check on this with our team!
Hello! Our team is wondering if you can share the custom domain URL you’re using for YouTrack? If it does contain anything personal or private let me know and we can have you share it via DM
