iOS shortcuts
I am looking for one-tap option to start the timer at least via either of the two solutions:
  • Enable running the shortcuts that will also trigger the live notification (the starting the timer is enabled but without the live notification triggering)
  • Enable start timer functionality via quick actions buttons or widgets on the Lock Screen
Great suggestions we can share with the team :slight_smile: Thank you!
