Android lock screen notification
On Android, if a user has “Sensitive notifications” set to off in the lock screen settings, then it’s not possible to start or stop timers with Toggl.
On the other hand, it is possible to do so with the default Android timer app. Would it make sense to change the Toggl notification from “Sensitive” to “public” when it’s sent to Android?
I found a workaround: you can add a tile to the quick settings menu by pulling down, and using the pencil icon to edit it. There’s a Toggl action which lets you start a new timer
Hey! That’s correct. Still, thanks for the feedback. It will be shared with the team. :slight_smile:
Feel free to share any other feedback you may have; this helps us improve the experience in the future!
