Is Rounding a paid feature?
Hi, just wondering if Rounding is a paid feature, because for me I can’t seem to access the feature near the Export button in the Reports screen. It only shows “Rounding Off” and won’t allow me to change it. Thanks!
The rounding feature in Toggl Track is a Premium feature, so you’ll need a Premium subscription to access it. That’s why you’re only seeing “Rounding Off” without the ability to change it on your current plan.
If you upgrade to Premium, you’ll be able to use the rounding feature in your Reports screen near the Export button to round your tracked time entries as needed.
