Reporting in 15 minute increments in Toggl 2.0
I am using Toggl 2.0 and I cannot seem to be able to find a way to report in 15 minute increments for billing. The rounding button just isn’t showing up so hoping someone can help.
Thanks in advance.
Time rounding in Toggl 2.0 is not currently possible based on the information available. It sounds like this feature may have changed or is no longer available in the updated version.
As a workaround, you could manually adjust your time entries before exporting your reports for billing purposes.
This is a great feature request though, and I will make sure to pass this feedback along to the product team!
Just another Toggl 2.0 deal-breaker. :frowning:
Hi! Rounding is now available :slight_smile:
Yes! I have been using it and it’s great!! Please tell the team “Thank you”. It’s great you all listen to your customers!!
