LiquidPlanner browser integration not working
We use Portfolio Manager (formerly called Liquid Planner) by Tempo. I see there are two options for Liquid Planner in the Integration page as there were (still are?) two versions of Liquid Planner; the legacy one and the next generation. We are using the next generation one so I have that ticked. However I am not seeing any Toggl Track button in the Portfolio Manager web app. I would expect to see this alongside the other buttons such as ASAP etc on the task form, as per this screenshot. Has anybody managed to get this working?
Regards
Darwood
Thanks for the detailed question, Darwood!
Unfortunately, the knowledge base does not contain specific details about the LiquidPlanner / Portfolio Manager browser integration to confirm whether the next generation version is fully supported or what might be causing the button to not appear.
What I can suggest in the meantime is using the Toggl Track browser extension directly to track time, as it allows you to start timers manually while working in any web app, even if the direct integration is not injecting buttons as expected.
If other community members have gotten this working with Portfolio Manager (next generation), hopefully they can share their experience here. It would also be worth checking that your browser extension is up to date, as integration button injection can sometimes be affected by extension version or browser updates.
@Support You should probably ask Development to fix this or remove it from your list of integrations. I’ve remembered that I wrote this integration originally but it stopped working after the upgrade to Chrome manifest v3 formats. It looks like Toggl have taken it inhouse since then but it’s still not working.
