https://api.track.toggl.com/api/v9/me/tags
Returns tags for the current user.
- cURL
- Go
- Ruby
- JavaScript
- Python
- Rust
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> { let client = Client::new().basic_auth("<email>", "<password>"); let json = client.request(Method::GET, "https://api.track.toggl.com/api/v9/me/tags".to_string()) .header(CONTENT_TYPE, "application/json") .send() .await? .json() .await?; println!("{:#?}", json); Ok(())}
Parameters
Query
| since | integer | false | Retrieve tags modified/deleted since this date using UNIX timestamp. |
Response
200
| Name | Type | Description |
| items | Array of object | - |
items
| at | string | When was created/last modified |
| creator_id | integer | CreatorID the user who created the tag |
| deleted_at | string | When was deleted |
| id | integer | Tag ID |
| integration_ext_id | string | The external ID of the linked entity in the external system (e.g. JIRA/SalesForce) |
| integration_ext_type | string | The external type of the linked entity in the external system (e.g. JIRA/SalesForce) |
| integration_provider | string | The provider (e.g. JIRA/SalesForce) that has an entity linked to this Toggl Track entity |
| name | string | Tag name |
| permissions | string | - |
| workspace_id | integer | Workspace ID |
403
500
