"Tags" Endpoints - GET Tags
https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/tags
List Workspace tags.
extern crate tokio;extern crate serde_json;use reqwest::{Client};use reqwest::header::{CONTENT_TYPE};#[tokio::main]async fn main() -> Result<(), reqwest::Error> {  let client = Client::new().basic_auth("<email>", "<password>");  let json = client.request(Method::GET, "https://api.track.toggl.com/api/v9/workspaces/{workspace_id}/tags".to_string())  .header(CONTENT_TYPE, "application/json")  .send()  .await?  .json()  .await?;    println!("{:#?}", json);  Ok(())}
items Array of object -
items​
at string When was created/last modified
creator_id integer CreatorID the user who created the tag
deleted_at string When was deleted
id integer Tag ID
name string Tag name
permissions string -
